Can I change one instance of a certain color in a video event?
COW Forums : VEGAS Pro
Raymond Pace
on Apr 1, 2015 at 3:11:46 pm
For example, pretend that this is an event on the Vegas timeline:
If I wanted to take all the instances of the color blue that occur in this event, and change them to a different color (white in this case is what I need), could I do so? If so, how?
Thanks.
PS, please let me know if I didn't explain clearly enough.
Graham Bernard
Re: Can I change one instance of a certain color in a video event?
on Apr 1, 2015 at 5:28:48 pm
I WAS going to suggest the 2nd Colour Corrector. But this way beyond that. You havoc a ton of different blues all over he place. If you're running VP 12/13, yes, the FX could be masked to the areas you want, but even so....
Grazie
Raymond Pace
on Apr 1, 2015 at 5:31:42 pm
What if there was fewer blue in the video event? That was just an example? I should have used something closer to what I'm actually working on?
Would you mind explaining what I would do with the Secondary Color Corrector?
Graham Bernard
on Apr 2, 2015 at 5:14:30 am
[Raymond Pace] "Would you mind explaining what I would do with the Secondary Color Corrector?"
Well, I did a Tutorial on how to do a 2-Colour on Black using the Secondary Colour Corrector. Here's that from 6 years ago:-
https://reels.creativecow.net/film/grazie-2colour-and-black-and-white-and-g...
Would that help you? It may give you an idea . . . ?
Grazie
