Masking problems
COW Forums : VEGAS Pro
Chris Jouett
Masking problems
on Mar 30, 2015 at 10:11:25 pm
I'm trying to make a lightsaber video using this technique
however whenever I add a new key frame to the mask it looks messed up when I go back to it. It'll be slightly to the left or slightly to the right of where it's supposed to be. Why is this?
Mike Kujbida
Re: Masking problems
on Mar 31, 2015 at 11:12:43 am
Make sure your preview window is set to Best/Full when you do this otherwise it will be off when you render, as you've already discovered :(
