Convert vts to other format
COW Forums : VEGAS Pro
Paul Gregory
on Mar 27, 2015 at 1:16:03 am
I wanted to know if there are any media players that can play iso files that allow you to keep all of the other features other than playing the feature file that allows you to maintain the other features of the original like motion menus,chapter points,additional audio tracks & subtitles?
I suspect not since isn't an iso file basically just a folder for the regular video_ts file that allows you to burn it to disk? The menu's are the the vts files. I understand that these be converted to some mpeg2 or other sort of file that can be played but does it happen with the necessary links to the appropriate part of the file?
If this can't be done then I suppose that it's even less likely for this sort of thing to be done with a Blu-ray?
Thanks in advance
Russ Froze
Re: Convert vts to other format
on Mar 27, 2015 at 5:53:00 am
Have you tried VLC media player?
Aleksey Tarasov
on Mar 27, 2015 at 8:40:23 am
Cyberlink PowerDVD ?
