Video File Shortened?!
COW Forums : VEGAS Pro
Gavin Rose
on Mar 26, 2015 at 2:31:56 am
So basically, all the video files I try to insert into Sony Vegas (Pro 13) end up being quite a bit shorter and sped up (or something like that). Here's a Gyazo of the problem: http://gyazo.com/a04a3c47f9f335a22399191e2c0837be
John Rofrano
Re: Video File Shortened?!
on Mar 26, 2015 at 12:15:17 pm
What codec do the files use? It might be that Vegas Pro is having a hard time reading the codec.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Gavin Rose
on Mar 26, 2015 at 5:38:21 pm
How would I figure out what codec they use?
John Rofrano
on Mar 27, 2015 at 12:00:03 am
Open them with a tool like MediaInfo. It should be able to tell you what codec is inside the AVI files.
~jr
Gavin Rose
on Mar 27, 2015 at 5:58:52 am
Not sure which ones the codec... http://gyazo.com/d52bc410626c378300eaadce0f566343
John Rofrano
on Mar 28, 2015 at 1:03:42 am
[Gavin Rose] "Not sure which ones the codec"
The codec is FICV which I've never heard of before and I'm certain that Vegas doesn't support. A quick Google search reveals that it's part of Mirillis Action! screen capture software.
You should probably convert them to a format that Vegas can edit like Motion JPEG (M-JPEG). A tool like AviDemux 2.5 might be helpful in accomplishing this.
~jr
Gavin Rose
on Mar 28, 2015 at 4:18:32 am
Not sure what happened.. http://gyazo.com/5ddcea8c51d33459316a3740febfd439
Once I get it up and running though, how would I convert it? What button would I press?
Thats so weird though! I used to input files from Aaction to Sony Vegas without any hastle! ;-;
John Rofrano
on Mar 28, 2015 at 2:52:43 pm
[Gavin Rose] "Once I get it up and running though, how would I convert it? What button would I press?"
Use these settings:
[Gavin Rose] "Thats so weird though! I used to input files from Aaction to Sony Vegas without any hastle! ;-;"
Do you have the Mirillis Action! screen capture codec installed? You'll need to install the codec so that the files can be read.
~jr
