Grabbing the Fade in offset gizmo
COW Forums : VEGAS Pro
Greg FitzPatrick
on Mar 25, 2015 at 7:41:11 pm
Does anybody have a suggestion for how to easily grab the Fade in offset gizmo? Eventually I latch on to it but often it is a hit and miss affair between Fade in offset and Trim event start. Must be a method...
John Rofrano
Re: Grabbing the Fade in offset gizmo
on Mar 26, 2015 at 12:13:22 pm
The Fade is only available in the upper corner. If you are grabbing the trim event then you are clicking too low. Just click in the upper corner. I have no issues with this at all. Also try zooming n a bit. The more you zoom into an event the easier it is to see the fade handle.
~jr
http://www.johnrofrano.com
http://www.vasst.com
