Sony Vegas Pro 11 Renders all of my MP4 29.97 fps videos as MP4 59.97 regardless of what my settings are.
COW Forums : VEGAS Pro
Rick Mallars
on Mar 24, 2015 at 4:34:26 am
Greetings Vegas gurus! My copy of Sony Vegas Pro 11 Renders all of my MP4 29.97 fps videos as MP4 59.97 regardless of what my settings are. And regardless of what frame rate I shoot in! I used a Sony Nex7 (Video: 00:00:20.020, 29.970 fps progressive, 1440x1080x12, AVC
Audio: 00:00:20.011, 48,000 Hz, Stereo, AAC)
I am attempting to render an MP4 using:
Frame size 1080 p HD (1920 x 1080)
Profile - Main
Frame rate 29.97
Field Order - Upper Field First
Pixel Aspect Ratio - 1.0
Constant Bit Rate - 14,000
Encode Mode - Automatic
When I render the file (no matter what I change the settings to even if I allow the source to adjust the frame rate or size) it ALWAYS comes out the same - 59 frames per second.
Can anyone share some ideas on what may be causing this to happen?
Thanks in advance!
Rick
John Rofrano
Re: Sony Vegas Pro 11 Renders all of my MP4 29.97 fps videos as MP4 59.97 regardless of what my settings are.
on Mar 25, 2015 at 12:46:00 am
[Rick Mallars] "Field Order - Upper Field First"
Why are you rendering progressive MP4 as interlaced? Are you sure you're not seeing 59.94 fields per second? which is 29.97 frames pre second? (i.e., 59.94i)
~jr
http://www.johnrofrano.com
http://www.vasst.com
Rick Mallars
on Mar 25, 2015 at 8:56:27 pm
Thanks! That fixed it! I didn't realize that's what I was doing. Nice to know that for the future. Thanks again!
Rick
John Rofrano
on Mar 26, 2015 at 11:48:34 am
You're welcome. Glad I could help.
~jr
