Sony Vegas x264wfv output changes red color
COW Forums : VEGAS Pro
Levan Katsadze
on Mar 22, 2015 at 5:11:02 pm
Hello, I have Sony Vegas Pro 13 x64, and I am trying to render a video.
When I render normally, with Sony AVC codec or MainConcept AVC, the output colors are just the same as input video.
But I want to x264wfv plugin to render the video into x264 (lossless or maybe CRF), I like x264wfv more, because I can focuse on quality than bitrate. Sony AVC and MainConcept AVC are actually headache in terms of outputing maximum quality with not huge size.
So, well, I rendered the video with x264vfw, here is the image of rendering settings:
and here is the ouput:
As you can see, the output video colors are almost identical, but only red colors are lighter than original video. I don't understand, what's wrong with x264wfv? Why it does not just make everything the same? why it changed red colors?
Well, I just want totaly same output in terms of color.
Steve Rhoden
Re: Sony Vegas x264wfv output changes red color
on Mar 23, 2015 at 7:10:55 am
Well, i dont know about x264wfv plugin, as that is not a Vegas
problem, it would be best for you to get in touch with its
developers and relate this same issue to them.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
John Rofrano
on Mar 23, 2015 at 10:59:52 am
May try using RGB instead of YUV? Your source is probably RGB and you may be loosing something on the color conversion. (just a guess)
~jr
http://www.johnrofrano.com
http://www.vasst.com
Levan Katsadze
on Mar 24, 2015 at 11:29:19 pm
Wow, Finally! I did it! I fixed this problem.
After soooooooo much Googling and testing and Googling and testing and testing, here is what I did finally:
At first, I'll say that this is the information of the source file:
Downloaded from: Youtube
Resolution: 3200x1800 (almost 4K)
Framerate: 30fps
Bit depth: 8 bits
Color space: YUV
Duration: 3 hours and 41 minutes
And, well, the Project Properties in Sony Vegas:
Pixel format: 32-bit floating point (video levels)
--> NOTE: the colors in Sony Vegas Preview window was absolutely the same as source colors. I mean, there was no problem about studio RGB vs Computer RGB.
And, this is what I did:
I just typed this text in the command line tool in x264wfv window:
--range pc --colormatrix bt709
That's it. It just rendered fine. Absolutely the same color output as source.
Video editing is cool :D Big headache, but cool :D
John Rofrano
on Mar 24, 2015 at 11:35:38 pm
Wow. Glad you figured it out and came back to share with the community. That's what makes the COW forums great! ;-)
~jr
Steve Rhoden
on Mar 25, 2015 at 1:07:57 pm
Good you got that sorted!
