Using Canon PF24 with Sony Vegas 12
COW Forums : VEGAS Pro
Rob Cioffi
on Mar 21, 2015 at 5:17:51 pm
I'm trying to use PF24 (AVCHD) footage for a 24p project. Is this possible? I tried converting the footage with Handbrake but some of the ghosting is actually worse. Thanks in advance!
Camera is HF10.
Aaron Star
Re: Using Canon PF24 with Sony Vegas 12
on Mar 22, 2015 at 4:35:53 am
Have you tried this?
http://renomath.org/video/linux/pullup/
John Rofrano
on Mar 22, 2015 at 11:56:43 am
PF24 is wrapped in 29.97 fps. Try using a 29.97 project and just render to 24p at the end. This will give Vegas Pro a change to remove the pulldown. I don't know if it will do it correctly but it's worth a shot.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Rob Cioffi
on Mar 22, 2015 at 6:00:41 pm
Thanks guys. John the render at 24p did not seem to work. Aaron I will give it a try but what I was hoping for was a 1 step GUI based solution like this one using Handbrake:
John Rofrano
on Mar 22, 2015 at 6:34:21 pm
[Rob Cioffi] "John the render at 24p did not seem to work."
Yea, it was worth a shot but I kinda thought it wasn't regular pull-down. You need program that knows how to deal with this proprietary format.
~jr
Rob Cioffi
on Mar 22, 2015 at 7:05:03 pm
There are some references to Cineform Neoscene being able to do this but it's no longer available.
Rob Cioffi
on Mar 22, 2015 at 9:30:40 pm
It seems like AVS Converter 8.3 is doing the trick. Thanks.
