Down convert problem
COW Forums : VEGAS Pro
Daron Wilkins
on Mar 15, 2015 at 8:38:15 pm
Hi, I recently recorded some HDV1080i footage on my Sony Z5U with a MRC1 recording unit. After checking the footage I found that it was distorted and poor quality. I looked at my camera and found that somehow the I link had been set to on and the down convert squeezed my video and recorded my footage as DV. Is there any way to get the footage back to HDV1080i or at least make it look better?
By the way I also posted this same question on Sony's forum in case you see it over there.
John Rofrano
Re: Down convert problem
on Mar 16, 2015 at 4:26:47 am
The down convert should be happening in the camera which means that you can turn off down convert and capture the footage again and you should get HDV this time.
© 2018 All Rights Reserved
