Event Pan/Crop Problem
COW Forums : VEGAS Pro
Joao Souza
on Mar 12, 2015 at 3:34:29 pm
If I try to make an event pan/crop zoom in three channels simultaneously, Vegas crashes no matter what type of file I try to render.
No, I won't group them and use their grouped parent motion to zoom cause event pan/crop zoom quality is way better.
What could be causing this?
Is it a known problem?
Thanks ;)
We have so much time and so little to do! / Willy Wonka
Graham Bernard
Re: Event Pan/Crop Problem
on Mar 12, 2015 at 5:48:30 pm
Supply a ScreenGrab, might help us?
To assist you in answering your question:
1] What is the media?
2] What are your project settings?
3] What are you encoding to?
4] Do you have GPU acceleration ON?
Grazie
Joao Souza
on Mar 12, 2015 at 5:59:10 pm
None of these matter cause it only happens while event pan/crop zooming 3 channels
It's an specific problem which have nothing to do with my settings which are the same as everybody use here and around the net, nothing different or special.
I guess you never saw that problem so you can't help me.
Thanks Graham.
Graham Bernard
on Mar 12, 2015 at 6:38:19 pm
I agree.
G
Mike Kujbida
on Mar 12, 2015 at 6:59:39 pm
Joao, what version of Vegas are you using? I just tried a 4 channel zoom out using Pan/Crop on stills and everything worked as expected.
edit: this was using Pro 12
Joao Souza
on Mar 12, 2015 at 7:38:01 pm
[Mike Kujbida] "Joao, what version of Vegas are you using? I just tried a 4 channel zoom out using Pan/Crop on stills and everything worked as expected.
edit: this was using Pro 12"
Hey Mike Vegas 11.0.
Did you render it?
My problem is about rendering it.
Mike Kujbida
on Mar 12, 2015 at 7:45:16 pm
Sorry but I went right from Pro 10 to Pro 12.
Are you using the latest build? A browse of the release notes shows a few issues with the Pan/Crop tool that were fixed at various times. The most recent one was in build 700/701.
Notable fixes/changes in version 11.0 (Build 700/701)
Fixed a hang that could occur when rendering when a pan/crop rectangle is moved completely off an image.
Joao Souza
on Mar 12, 2015 at 7:51:19 pm
[Mike Kujbida] "Sorry but I went right from Pro 10 to Pro 12.
Fixed a hang that could occur when rendering when a pan/crop rectangle is moved completely off an image."
Mine is build 700.
I google'd but found nothing about that zooming problem.
If everybody with Vegas 11 had that problem so I'd consider moving to 13.
My puter is 32bit so I won't change vegas and windows because of a zoom problem LOL
Mike Kujbida
on Mar 12, 2015 at 7:54:30 pm
Very strange. The only thing I can suggest is to post your veg file and let us try to see if we can replicate your problem.
Joao Souza
on Mar 12, 2015 at 8:14:27 pm
[Mike Kujbida] "Very strange. The only thing I can suggest is to post your veg file and let us try to see if we can replicate your problem."
How could I do that?
Steve Rhoden
on Mar 13, 2015 at 11:14:47 am
Very strange, not sure what could be your problem. However
i use Vegas 13 and tried what you are doing several times with
no rendering issues at all.
Could possibly been a bug in Vegas 11 that nobody hardly noticed!
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Joao Souza
on Mar 13, 2015 at 11:54:56 am
[Steve Rhoden] "Very strange, not sure what could be your problem. However
Hey Steve, yeah that's strange let's say zooming starts after 15 seconds, till there rendering was perfect, once zooming started, after a few seconds Vegas disappears from the screen.It only happens with 3 tracks or more and the funny thing is I need 3 tracks to do that kind of zoom simulating 3D like:
Channel 1 = background
Channel 2 = things in the middle
Channel 3 = things in the front
They have different zooming to look like real life I mean, the closest things are to the cam, they move faster.
Damn, if only that bug started with 4 channels and not 3 LOL
