My Sony Vegas - Video Event FX Tab Is not working!
COW Forums : VEGAS Pro
Keenan Lewin
on Mar 1, 2015 at 12:45:15 pm
Hi im having a really anonying problem with Vegas 13 at the moment
Image: http://imgur.com/RdupDJ4
What is going on is that inside the "Video Event FX" Tab the Options to edit the FX just cuts off.
Someone help pls!
John Rofrano
Re: My Sony Vegas - Video Event FX Tab Is not working!
on Mar 2, 2015 at 12:34:00 am
What do you have your font DPI set to in Windows? If you are using larger than the normal font DPI you have identified the problem. Set your DPI back to 100% and it should work properly.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Keenan Lewin
on Mar 2, 2015 at 4:58:21 pm
I've changed it and there is no difference. Any clues?
John Rofrano
on Mar 2, 2015 at 11:07:49 pm
What was it before and what did you change it to? Can you provide screenshots of your DPI settings? Did you reboot the computer after changing it?
~jr
Keenan Lewin
on Mar 3, 2015 at 4:21:13 am
Ok, here are the screenshots in one image
- OS: Windows 8.1
http://i.imgur.com/IbOlFPM.png
and yes i did reboot also before i think it was the same
John Rofrano
on Mar 3, 2015 at 6:50:37 pm
I seems Windows 8.1 has different options than Windows 7 because I don't have those "Changing the text size only" options. Perhaps those are the problem. I see a few yellow caution icons. That might be what's causing it.
If you look at your original screen shot, the fonts are much larger in your Video FX window than other windows. It looks like this is a font size problem. If you can get everything back to the defaults, it might solve the problem.
~jr
Keenan Lewin
on Mar 4, 2015 at 10:28:04 pm
It Made No Difference :(
I Changed The Settings to default and i even re-installed the program!
John Rofrano
on Mar 5, 2015 at 1:39:08 pm
I'm out of ideas at this point. You may have to contact Sony support. Usually changing the font Dpi fixes problems like this. (sorry)
~jr
Keenan Lewin
on Mar 9, 2015 at 7:27:26 pm
i have contacted sony and they are not much help.... -_-
