Particle Illusion Problem
COW Forums : VEGAS Pro
Joao Souza
on Feb 25, 2015 at 6:16:51 am
There are some emitters like fire with smoke, it doesn't matter what I do it always looks crap when I import it to Vegas, smoke looks really dark and like a solid spot and not like smoke with soft edges that blend with the background image or video.
I'm "save output" PNG file, save alpha and remove black bg.
While playing on a background image, it looks perfect but when I import it to Vegas(without that background) and put over the same background it looks the way I explained above.
How to fix that?
Thanks.
We have so much time and so little to do! / Willy Wonka
Graham Bernard
Re: Particle Illusion Problem
on Feb 25, 2015 at 6:40:36 am
I save to AVI. That works for me. Why PNG?
G
Graham Bernard
on Feb 25, 2015 at 8:25:15 am
Here are my "typical" settings:-
Joao Souza
on Feb 25, 2015 at 8:38:17 am
Because I want no background and everybody I know who works with PI told me PNG would give me the best results, are they wrong?
BTW when I try to save to AVI like you, that output options box doesn't let me change anything, all settings are locked, is there a way to unlock them?
Graham Bernard
on Feb 25, 2015 at 9:01:26 am
Are they wrong? - I wouldn't say that, but you end up with a collection of stills. I couldn't work like that. From your "response", it would appear you aren't aware that PNG isn't the only Render-out option that keeps the ALPHA channel?
And to quality, I'm getting 1920x1080.
Cheers
Grazie
Joao Souza
on Feb 25, 2015 at 9:15:03 am
Read my reply again = "BTW when I try to save to AVI like you, that output options box doesn't let me change anything, all settings are locked, is there a way to unlock them?"
If I try to save to AVI, I can't check save alpha channel box or any other box, they're all locked.
Joao Souza
on Feb 25, 2015 at 9:38:49 am
As AVI render settings are locked, I tried something different,as I couldn't choose save alpha channel, I exported with black background and in Vegas I changed channel composite mode to screen, it worked.
Why the hell AVI output settings are locked?
Graham Bernard
on Feb 25, 2015 at 10:16:15 am
[Joao Souza] "Why the hell AVI output settings are locked?"
You need an AVI CODEC option that WILL support ALPHA and then render the ALPHA Channel.
Cheers
Grazie
Joao Souza
on Feb 25, 2015 at 10:33:13 am
Please tell me one.
I installed Lagarith but even when choosing it still avi options are locked.
I installed Huffyuv too but still settings are locked, choosing codec is a screen after AVI output settings so it's locked before I choose any codec so I can't go to the second screen and choose a codec then return to the output options and see if settings are unlocked.
Weird LOL
Bob Peterson
on Feb 25, 2015 at 3:34:46 pm
What software are you using to separate the smoke from the background? My suspicion is that your separation is not as good as you think it is. The imperfections are hidden by the black background. You are probably seeing the true selection in Vegas. It probably does not look as good because the original black background is no longer present.
Joao Souza
on Feb 25, 2015 at 6:42:12 pm
What software?
I don't understand your question, I create smoke with PI then open it in Vegas.
John Rofrano
on Feb 25, 2015 at 6:24:12 pm
[Joao Souza] "While playing on a background image, it looks perfect but when I import it to Vegas(without that background) and put over the same background it looks the way I explained above. "
What did you set the Alpha Channel to on the Event on the Timeline? If you used Straight (unmated), try Pre-multiplied (Black).
~jr
http://www.johnrofrano.com
http://www.vasst.com
Joao Souza
on Feb 25, 2015 at 6:40:27 pm
Looks like crap the same way.
I gotta find out why when I try to save to AVI, I can't select save alpha, why are all settings locked?
I just find out if I try to import an avi video,PI crashes................always.
Graham Bernard
on Feb 26, 2015 at 11:27:31 am
[Joao Souza] "I gotta find out why when I try to save to AVI, I can't select save alpha, why are all settings locked?"
Hmmm...
Here are all my AVI options and therefore my Settings for AVI are live:-
You have NO live AVI options?
G
Joao Souza
on Feb 26, 2015 at 1:00:46 pm
My PI is different than yours(mine is 3.0), that save output box has only settings for file output, codec options are in the second box, only with avi options are locked, I can't check save alpha channel box.
Here1s save output box, all settings are blocked, I click ok then a second box let me choose a codec but still I couldn't check save alpha box.
Graham Bernard
on Feb 26, 2015 at 1:20:10 pm
[Joao Souza] "I can't check save alpha channel box."
I just ignore that and click OK. Then I get the CODEC stuff.
My PI is 3.09.
G
Joao Souza
on Feb 26, 2015 at 1:26:07 pm
So you don't know why save alpha box is locked or how I could unlock it?
Graham Bernard
on Feb 26, 2015 at 2:16:10 pm
If you're asking, then my best guess would be that you need to go to the next Screen select the AVI that allows for ALPHA, which works for me, and then, as I've experienced, click the save ALPHA.
G
Joao Souza
on Feb 26, 2015 at 2:20:09 pm
I already said more than 3 times that options are locked no matter whatever codec I choose.
Codecs are in the second box so once I chose a codec, I can't return to the 1st box.
A friend of mine jus brought me PI 3.04.
It looks like yours and.................when I click RENDER it says = Could not find an acceptable pixel format!
What the hell does that mean?
LOL
Graham Bernard
on Feb 26, 2015 at 2:28:35 pm
Do you think you need to reinstall Particle Illusion? Sounds like parts of the program aren't aware of what you've installed. Have you got the latest version to install?
What do you think?
Grazie
Joao Souza
on Feb 26, 2015 at 2:39:09 pm
"A friend of mine jus brought me PI 3.04.
LOL"
I found the problem, when I click render it asks if stage should be 100%, I have to set NO then it works.
Graham thanks for your patience ;)
Graham Bernard
on Feb 27, 2015 at 9:03:02 am
[Joao Souza] "I have to set NO then it works."
Good! - At least we had an opportunity to establish as many of the parameters that are present in pI!
Grazie
