Spin effect like this?
COW Forums : VEGAS Pro
Andy Julianto
on Feb 20, 2015 at 8:28:40 pm
Hello, just wanna ask can you do this spin effect like in this video in Sony Vegas?
The spin effect like the cards of course, trying to use mirror effect with my own picture, but i guess its different way?
Russ Froze
Re: Spin effect like this?
on Feb 21, 2015 at 3:29:53 am
Something like this example file?
8589_spineffect.veg.zip
Andy Julianto
on Feb 21, 2015 at 3:07:10 pm
yeah like that, can you tell me how to do it? because i'm not familiar enough with Track Motion.
thanks again!
Russ Froze
on Feb 22, 2015 at 7:24:46 am
OK, the trick is to change Track Motion from Source Alpha to 3D source Alpha.is
The drop down menu to make changes is the green icon to the right of Track Level slider. Change this from "source alpha" to "3D source Alpha". Then open Track Motion and you will have a 3D viewer / controller. Play around with it to see how things work.
In the sample veg, simply replace the generated media and make adjustments as needed.
Russ Froze
Timothée Ferreol
on Mar 21, 2015 at 10:17:39 pm
Put your track mode in "Alpha Source 3D" then in the track movement windows create 2 keyframes and change the "Y" orientation of the second keyframe.
It will spin it but won't show an other face of the card, it will just show it upside down.
