VLC as a recording option for HDMI/USB3 capture devices.. but file capture encoded format..?
COW Forums : VEGAS Pro
Jean-Pierre Desrochers
on Feb 19, 2015 at 4:11:52 pm
I use VideoLan VLC to record HDMI feed going to
my Magewell XI100DUSB-HDMI HDMI to USB 3.0 Video Capture Dongle.
VLC works very well with this dongle and offers
many file capture encoding formats to be saved (MP4, AVI, MJPEG, etc..). Ok.
Now I need some advices on what encoding format parameters
to use with VLC to make an easily 'importable' file to use
in Sony Vegas Pro 13 for editing...
I just read that BandiCam app can record and save to
Sony Vegas importable file which would be
MJPEG video & PCM audio (supposed to be Sony Vegas native import format..)
but I'd prefer to use VLC as a recording option.
So far I capture at 1920x1080i on Windows 8.1.
Any advices on encoding format parameters ??
J-P Desrochers
Quebec, Canada
Stephen Mann
Re: VLC as a recording option for HDMI/USB3 capture devices.. but file capture encoded format..?
on Feb 20, 2015 at 5:29:45 pm
Personally, I would use AVI as it's only lightly compressed. MPEG and MJPEG are heavily compressed and really a pain to edit.
I've never used VLC as a recorder - let us know how well it works.
I am not sure of your workflow - does the Magewell dongle just write a file to your HDD? Video in and USB3 out almost says that it wants to make a file, so I don't see where VLC fits in the equation.
Steve Mann
MannMade Digital Video
http://www.mmdv.com
on Feb 20, 2015 at 6:36:14 pm
Ok,
Just watch this video about The Magewell dongle:
When plugged to a suitable USB3 port
This dongle is shown as a directshow device in the
PC video and audio devices. No drivers required to work.
Now I used VLC to use the dongle incoming video.
So inside VLC I select:
- Media/Open a capture device
- Select both XI100DUSB-HDMI for video
and XI100DUSB-HDMI(audio device) for audio
- I then select read (preview) or convert to save the incoming video
to a file.
The 'convert' option brings a wide variety of encoding option
for tha saved file.. That's there that I get confused..
I don't know what the best settings should be used
to get the final captured file importable to Vegas Pro..
Hope this is much understandable.
What are your file format/settings suggestions for Vegas Pro ?
J-Pierre
J-P Desrochers
Quebec, Canada
on Feb 20, 2015 at 8:47:08 pm
And I forgot to mention:
You stated:
>Personally, I would use AVI as it's only lightly compressed. MPEG and MJPEG >are heavily compressed and really a pain to edit.
You are right on that.
That's the file type I'd like best.
But since AVI is only a container I still can't figure
what to put inside as encoding..
On other forums some users say they are using
MPEG-2 or M-JPEG for Vegas compatibility,
other say MP4 is the way to go for import in Vegas.
Very confusing !!!
But again the container's inside parameters are
always unknown.
My video parameters to encode are
video: 1920x1080i 60fps
audio: stereo PCM 48khz
JP
J-P Desrochers
Quebec, Canada
Stephen Mann
on Feb 21, 2015 at 10:05:04 pm
That's quite a device. And reasonably priced, too.
So your only encoder options are MPEG and variations of MPEG?
Well, since MPEG2 is a delivery format for DVD and MPEG4 is a delivery format for online, that would seem to point to M-JPEG. But I know really little about M-JPEG.
Have you tried looking at the output file using MediaInfo?
Steve Mann
http://www.mmdv.com
on Feb 22, 2015 at 6:28:31 pm
Steve,
Here are the summaries of 2 captures (4:3 then 16:9) I've done
and read using mediainfo:
- 10 sec capture on 4:3 Canopus ADVC(firewire)
capturing to DV AVI using Vegas Pro 13
General
Complete name : D:\Dossiers video\Capture general\(Unknown) - Clip 001.avi
Format : AVI
Format/Info : Audio Video Interleave
Commercial name : DV
File size : 38.3 MiB
Duration : 10s 544ms
Overall bit rate mode : Constant
Overall bit rate : 30.5 Mbps
TAPE : (Unknown)
TCOD : 512877365000
TCDO : 512982803667
VMAJ : 4
VMIN : 0
STAT : 316 0 3.433988 1
DTIM : 0 0
Video
Format : DV
Codec ID : dvsd
Codec ID/Hint : Sony
Bit rate mode : Constant
Bit rate : 24.4 Mbps
Encoded bit rate : 28.8 Mbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:1:1
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Time code of first frame : 14:14:47;23
Time code source : Subcode time code
Stream size : 36.2 MiB (94%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 1.93 MiB (5%)
Alignment : Aligned on interleaves
Interleave, duration : 264 ms (7.90 video frames)
Interleave, preload duration : 266 ms
- 10 sec capture on 16:9 Magewell HDMI dongle (USB3)
capturing to MPG2 using VidBlaster demo
General
Complete name : D:\Dossiers video\Capture general\Test Magewell\VidBlaster test Magewell 10 secondes 1920x1080 60fps.mpg
Format : MPEG-PS
File size : 6.46 MiB
Duration : 10s 633ms
Overall bit rate mode : Variable
Overall bit rate : 5 093 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=15
Bit rate mode : Variable
Bit rate : 4 671 Kbps
Maximum bit rate : 8 000 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.075
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
Stream size : 5.92 MiB (92%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 10s 560ms
Bit rate : 320 Kbps
Delay relative to video : -10ms
Stream size : 413 KiB (6%)
Comparing both infos can you tell if the MPG2 is too much
compressed to be used for editing in Vegas Pro 13
compared to the standard DV AVI capture format Vegas
uses when capturing ?
J-Pierre
J-P Desrochers
Quebec, Canada
on Feb 23, 2015 at 7:09:03 pm
Steve,
I just found a program called VMix that seems to do exactly
what I'm looking for..
- Recognise the Magewell USB3 dongle device,
- Capture and save to many possible 'not too compressed'
encoding formats.
The best capture/encoding I found so far would be the following:
(MediaInfo text dump of a 60sec 1920x1080i 50Mbps bit rate, 48khz PCM audio)
General
Complete name : D:\Dossiers video\Capture general\Test Magewell\vmix capture - 23 février 2015 - 01-38-34 AVI-1920x1080 NTSC_2997p MJPEG Encoder DMO 90% compression.avi
Format : AVI
File size : 347 MiB
Duration : 1mn 0s
Overall bit rate : 47.8 Mbps
Video
Format : JPEG
Codec ID : MJPG
Duration : 1mn 0s
Bit rate : 46.2 Mbps
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.744
Stream size : 335 MiB (97%)
Audio
Format : PCM
Codec ID : 1
Duration : 1mn 0s
Bit depth : 16 bits
Stream size : 11.1 MiB (3%)
Interleave, duration : 20 ms (0.60 video frame)
Interleave, preload duration : 80 ms
Other encoding options in Vmix are
AVI(AVI or MKV)
MPEG-2 (Adjustable bit rate from 1 to 75mbps)
WMV
MP4
Do you think these above AVI settings are a good compromise
to save my captured files to be afterward edited in Vegas Pro ?
Or could they be more compressed and still keep a good quality
to edit ?
JP
J-P Desrochers
Quebec, Canada
on Mar 29, 2016 at 3:08:26 pm
Steve, did you check my 2 last posts (one year old..)?
Your reply would be very useful..
Thanks.
JP
J-P Desrochers
Quebec, Canada
Andrew Losurdo
on Sep 5, 2016 at 2:28:16 am
I buy a Seetec HDMI to USB3.0 capture from Alibaba Trade Assurance.
I think it is a really nice tool.So I would like to share it here.
-No drivers to install and works with most software on PC and Mac.
-Allowing live video streaming, webcasting or video conferencing to Skype, Facebook Live, Youtube Live,etc.
-Can capture various HD video sources with resolutions up to 1920x1200p @ 60fps.
-Get power from the PC directly.
-USB3.0, 300-350MB/s throughput and it is compatible with USB 2.0 40MB/s.
Input Formats:
Resolutions: 640x480/720x480/720x576/768x576/800x600/1024x768/1280x720/1280x800/1280x960/1280x1024/1368x768/1440x900/1600x1200/1680x1050/1920x1080/1920x1200/640x360/856x480/960x540/1024x576
Frame Rate: 25/29.97/30/50/59.94/60 fps
Output Formats:
640×480/720×480/720×576/768×576/800×600/1024×768/1280×720/1280×800/1280×960/1280×1024/1368×768/1440×900/1600×1200/1680×1050/1920×1080/1920×1200/640×360/856×480/960×540/1024×576
The Support of OS
Windows 7
Windows 8
Windows 10
Windows Server 2008 R2
Linux (Kernel version 2.6.38 and above)
OS X (10.8 and above)
Android
You can check it on the Alibaba link:
https://wholesaler.alibaba.com/product-detail/reliable-and-flexible-solutio...
Hope this will help you.
Andrew
