What is the best way of prepairing proxy files for Vegas?
COW Forums : VEGAS Pro
leaning less
on Feb 14, 2015 at 1:11:11 am
Usually i convert video in MPEG2 with low resolution and high bitrate and keeping the original file name. Is it advisable instead of it to use editing formats Apple ProRes or Avid DNxHD?
Norman Black
Re: What is the best way of prepairing proxy files for Vegas?
on Feb 14, 2015 at 3:34:19 am
Best varies in the eye of the beholder.
The easiest way would be to use the Vegas smart proxy feature.
If you want more control then using the proxy features of the Vegasaur or VASST Ultimate S utilities are pretty easy to use.
John Rofrano
on Feb 14, 2015 at 1:16:35 pm
[Norman Black] "VASST Ultimate S utilities are pretty easy to use."
We (VASST) also have a proxy generator/swapping plug-in called GearShift that can do this. Check to be sure that it supports the video formats that you are using.
It will render the proxies and then swap between proxy and original media any time you want.
~jr
http://www.johnrofrano.com
http://www.vasst.com
