4k workflow for HD output
COW Forums : VEGAS Pro
mark thompson
on Feb 4, 2015 at 9:00:58 pm
I think this may have been asked before but ...I have some 4K footage which was shot at 3504 x 2326. I need to delver that at HD 1920x1080.
I did an initial Render and everything looks very good but the aspect ratio is wrong (1.5 instead of 1.777). I need as much of the frame as I can get so I'm thinking I need to drop 177 lines from the top and bottom.
What is the easiest way of doing that?
Thanks in advance
mark
Steve Rhoden
Re: 4k workflow for HD output
on Feb 7, 2015 at 9:56:45 am
You just start Vegas with a project settings of the 1920 x 1080
and drag your 4K content to the timeline and can go in the
Event Pan/crop window of your video on the timeline, right click
and select: Match Output Aspect
That's the best and proper workflow.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
mark thompson
on Feb 9, 2015 at 10:56:14 am
Steve,
thanks for that. I gave it a go and it did a pretty good job.
The video comes out looking good and everything is there except that it is very letterboxed.
I think the main problem is the way it was shot, i.e., there probably were some better options that would have scaled down to 16:9.
Anyway, it looks good enough for the purposes intended.
thanks
mark
