Rendering issue
COW Forums : VEGAS Pro
Derrick Gray
Rendering issue
on Feb 3, 2015 at 1:02:12 am
I am trying to render a video in Movie Studio 13 that will be played on a large movie cinema screen. Per the specs it needs to be:
1. .mov file
2. 1920 x 1080
3. H.264 compression
4. 24 fps
7I followed your video and changed my settings through the "customize template" tab. However for some reason the file is rendering very small (last time was 352x288p).. Any idea on what I'm missing or doing wrong?
Dave Osbun
Re: Rendering issue
on Feb 3, 2015 at 8:50:07 am
Take a screenshot of your 'render as' settings and post it up here, so we can see what the video settings are.
John Rofrano
Re: Rendering issue
on Feb 6, 2015 at 12:13:04 pm
I'm not sure what template you are modifying but Movie Studio is incapable of creating an AVC/H.264 QuickTime file. The best you can do is render to MP4 using MainConcept AVC and then rename the .mp4 file to .mov. The MP4 container is a proper subset of the MOV container so this should work.
© 2018 All Rights Reserved
