How may I copy all the keyframes and masks from one clip to another?
COW Forums : VEGAS Pro
Xavier Dolz
on Feb 2, 2015 at 1:48:46 pm
Hi, I want to copy all the keyframes and masks I have from clip to another clip. For example, let's imagine I have two videos of the same lenght, and I worked hard in the first video to place the keyframes, the masks and I like the results.
It is a royal pain having to work in the second video placing again the keyframes and again the masks...
Imagine you have 10 videos, then you have to repeat the process all the time...
It would be very cool if I work in the keyframes and masks of the first video, and then, I place in the timeline the other videos and then I copy the keyframes and masks from the first video to the other videos...
But how may I do that?
Cheers
Mike Kujbida
Re: How may I copy all the keyframes and masks from one clip to another?
on Feb 2, 2015 at 4:08:19 pm
Copy the first event (the one with the masks, etc.). Click the next one, then right click it and select Paste Event Attributes.
I just tried this with two stills and it worked so it should work with video as well.
Keep in mind that you may have to move the mask around each new event (what Vegas calls a clip) if the desired position changes on you.
Good luck.
