Stacking clips together
COW Forums : VEGAS Pro
Ged Jurga
on Jan 31, 2015 at 3:35:20 am
Is there a way to stack clips together which are scattered across the timeline? I have around 18 hours of footage and i went through each clip and cut it, now dragging each clip closer to each other seems very time consuming i was wondering if there is a button(or a script) that i can use to stack them all together side by side?
Heres a screenshot of a small section which i want to put all together without draggin each of them to each other.
Any ideas?
Thanks in advance!
John Rofrano
Re: Stacking clips together
on Jan 31, 2015 at 4:38:00 am
[Ged Jurga] "is a button(or a script) that i can use to stack them all together side by side? "
We have a script called VASST Event Tool that can do that and a whole lot more and its only $9.95 USD.
Just use Close Event Gaps on Selected Track(s). As the name implies it will close all of the gaps between your events.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Ged Jurga
on Jan 31, 2015 at 8:49:52 am
awesome! Thanks John!
