render pixelly
COW Forums : VEGAS Pro
Macca Baz
render pixelly
on Jan 28, 2015 at 10:37:49 am
ever render I make looks like the photo... very pixelly with colours.
(Looks like i am viewing an image over remote server)
The video has only 2 video tracks. One is the glasses image on top (screen blend mode)
The video under has all the images and video track with a track motion 2D glow.
I have rendered much more complicated projects in past with less problems than this.
I unchecked the smart resample too but still the same. i have rendered as mp4, wmv , mpg2 & avi with the same results. It looks fine in preview window.
please help.
Macca Baz
Re: render pixelly
on Jan 28, 2015 at 10:42:54 am
trying to post image to show what i mean but forum keeps putting me in circles.
Macca Baz
Re: render pixelly
on Jan 28, 2015 at 10:49:44 am
how does this forum work with image uploads? trying to attach, says its done but never show on thread.
Macca Baz
Re: render pixelly
on Jan 28, 2015 at 10:58:01 am
https://www.dropbox.com/s/c62hi7l3mpwzt07/pixelly.jpg?dl=0
dropbox link to image cant attach to forum.
Macca Baz
Re: render pixelly
on Jan 28, 2015 at 11:20:20 am
tried render in 720p also.. its just the same.. really horrible looking. Tried many different render settings now... changed VBR to constant, changed between 720p/1080p, disabled force resample.
please help, I may have to just go boot up my mac and redo it in there, but i prefer vegas interface.
Aleksey Tarasov
Re: render pixelly
on Jan 28, 2015 at 12:26:22 pm
Are you sure that there are no effects applied to Video Output Bus (or track/media/event)?
Also make sure that Split Screen View button is not checked (in the Video Preview Window)
John Rofrano
Re: render pixelly
on Jan 28, 2015 at 1:13:24 pm
Does it look fine in the preview and only bad when rendering?
Have you viewed it with Preview Best (Full)?
I'm trying to determine if this is a project problem or render problem. Feel free to post a screen shot of your timeline if you think it would help. Perhaps your Track Composite Mode is what's causing the problem.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Macca Baz
Re: render pixelly
on Jan 28, 2015 at 3:00:44 pm
hi i changed the track composite mode as i thought it may have been problem. used a mask instead to show the glasses at side. but its still the same.
looks fine while in vegas.
John Rofrano
Re: render pixelly
on Jan 28, 2015 at 1:07:24 pm
[Macca Baz] "how does this forum work with image uploads? trying to attach, says its done but never show on thread."
First you upload the image (I assume you found this):
Then choose your file, upload your image, select it in the list of uploaded images, and copy and paste the url into your post:
Then if you just want to refer to one you've uploaded previously, just select it from the list and copy and paste the URL:
~jr
Macca Baz
Re: render pixelly
on Jan 28, 2015 at 3:11:45 pm
hi there was no effects applied,
I thought it may have been a problem with the images so I tested with different ones.
It is still the same....
it is a very blocky effect as if there are lots of squares.
This was a brand new render with noting in project except a few images placed on timeline.
again looks perfect in timeline
john bolton
Re: render pixelly
on Jan 28, 2015 at 3:58:23 pm
Have you any other 3rd party codex loaded like Klite?
John Rofrano
Re: render pixelly
on Jan 28, 2015 at 8:23:23 pm
What render template did you use? The render type and the template name? Perhaps post a screen shot of the templates video tab.
~jr
Macca Baz
Re: render pixelly
on Jan 29, 2015 at 8:31:43 pm
I have tried many of them, render to high quality avi, wmv,mp4.
I redone it in final cut pro just to save any hassle & it looks fine.
Would like to figure it out for any other projects though.
John Rofrano
Re: render pixelly
on Jan 30, 2015 at 4:41:01 am
[Macca Baz] "Would like to figure it out for any other projects though."
I think it would help if you explained what you were trying to achieve because you were using a Mask compositing mode but you didn't really have a Mask and you need to understand that placing a track into a Compositing Mode other than Source Alpha will affect all of the tracks below it whether you want it to or not. So you need to use track compositing modes very carefully. I don't think that what you were doing even needed a composting mode but you would have to explain what it is you were trying to achieve so that we can suggest alternate ways of achieving it.
~jr
Norman Black
Re: render pixelly
on Jan 28, 2015 at 7:52:04 pm
With the information given...Preview fine...render as pixelated.
It sounds like your render bitrate it too low. The preview window is uncompressed, before being set to an encoder (render as), so any encoding artifacts will never been seen in the preview window.
