Best way to bring 1080p50 to blu-ray?
COW Forums : VEGAS Pro
Sam Wilson
on Jan 22, 2015 at 11:02:55 am
Hi there,
I created a little film of my last vacation in Sony Vegas. Now I want to burn this on a blu-ray. I rendered the film in 1080p50 XAVC (because most of my footage uses this properties). I'm aware of the issue, that the blu-ray-standard doesn't support 50p. As this is my first blu-ray-authoring I don't have any experience.
It would be nice if an authoring-pro could give me advice: Is it a good idea to convert to 1080i50 or should I stick with 50p and convert to 720p50? Authoring will be done in DVD Architect Pro 6.
Thanks in advance
Sam
John Rofrano
Re: Best way to bring 1080p50 to blu-ray?
on Jan 22, 2015 at 12:55:53 pm
[Sam Wilson] "Is it a good idea to convert to 1080i50 or should I stick with 50p and convert to 720p50? "
I would convert it to 1080-50i. I don't think that lowering the resolution is worth the benefit of the additional frame rate (if any).
~jr
http://www.johnrofrano.com
http://www.vasst.com
Sam Wilson
on Feb 3, 2015 at 2:35:17 pm
Thanks for your answer. I tried both and 1080i50 is the way to go - as you said.
John Rofrano
on Feb 4, 2015 at 1:07:29 pm
You're welcome. I glad that worked out for you.
~jr
