problem with psd and alpha chanel
COW Forums : VEGAS Pro
Eman Abdo
on Jan 21, 2015 at 1:45:55 am
hi all
i have a problem that is distroying my work
i will try to explain the problem
it is whith psd file or alpha avi video or any transparent objects when i put it on my video it seems like it strech and get disorted all over the screen not all the video but frequently in the preview and same when rendering
i'm using sony vegas 11 and tried 12 but it has the same problem
i tried to change frame rate but nothing is solved
any suggestion please
thanks in advance
David Eon
Re: problem with psd and alpha chanel
on Jan 22, 2015 at 5:30:12 am
Click on the PSD Event in the timeline
Use the Pan/Crop Editor (Right Click > Video Pan/Crop)
Then under Source set > Maintain aspect ratio...No
and > Stretch to fill frame...Yes
Also turn OFF Lock Aspect Ratio (rectangle and arrow button on left side - third from bottom)
Then set the Position Width and Height to the same settings as the original PSD.
Then turn ON Lock Aspect Ratio (rectangle and arrow button on left side - third from bottom)
And now you can resize it as needed without it stretching.
Let me know how it works for you!
DavidEon
