Vegas Crash Unmanaged Exception 0xc0000005 Before Splash Screen
COW Forums : VEGAS Pro
Chris Rogers
on Jan 18, 2015 at 10:55:05 pm
Problem Description
Application Name: Vegas Pro
Application Version: Version 13.0 (Build 310) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Fault Address: 0x00007FF687049E00
Fault Offset: 0x0000000000819E00
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Process Version: Version 13.0 (Build 310) 64-bit
Process Description: Vegas Pro
Process Image Date: 2014-04-29 (Tue Apr 29) 20:38:06
I haven't used the program in a few months, and when I went to fire it up today I get an immediate Problem Report screen - not even the Splash Screen shows up. I have tried disabling my video card and running as administrator, but I cannot get anything besides the Problem Report.
John Rofrano
Re: Vegas Crash Unmanaged Exception 0xc0000005 Before Splash Screen
on Jan 19, 2015 at 11:54:54 am
[Chris Rogers] "Application Version: Version 13.0 (Build 310) 64-bit"
The latest build is 428. Try updating and see if that cleans things out and gets you going again. If not, I would completely uninstall and re-install. It's really hard to say what might be going on. You might and to contact Sony.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Norman Black
on Jan 21, 2015 at 4:02:31 am
Try starting Vegas while holding the Ctrl+Shift keys down. That will reset Vegas to default preferences. Also answer yes to the option to delete saved data.
