Four point node machine gun shortcut
COW Forums : VEGAS Pro
John Perez
on Jan 18, 2015 at 11:54:03 am
I want to lay down four nodes to control an envelope. I know there's a way to do it because I've accidentally done it before. Instead I have to manually add each node along the envelope. Does anybody know how to do this?
As always thanks so much to you guys...Johnny In Orlando
John Rofrano
Re: Four point node machine gun shortcut
on Jan 18, 2015 at 3:33:35 pm
[John Perez] "I want to lay down four nodes to control an envelope. I know there's a way to do it because I've accidentally done it before. Instead I have to manually add each node along the envelope. Does anybody know how to do this?"
Create a Timeline Selection of the area that you want to control and then left-click your mouse to pull down on the envelope line and 4 nodes will magically appear at the edges of the selection.
~jr
http://www.johnrofrano.com
http://www.vasst.com
John Perez
on Jan 18, 2015 at 10:16:32 pm
John Rofrano, you are simply the best.
John Rofrano
on Jan 18, 2015 at 10:39:36 pm
I assume it worked. ;-) great!
~jr
