Reading Close Captioning when importing
COW Forums : VEGAS Pro
Linda O'Connell
on Jan 13, 2015 at 9:39:17 pm
I am using Vegas 11.
I am importing old home movies...mostly these files are MPEG 2. But whenever I import these it takes forever because it also says it is "Reading Close Captioning"
Is there an option so it doesn't do that on importing? I don't ever use close captioning.
Mike Kujbida
Re: Reading Close Captioning when importing
on Jan 14, 2015 at 1:44:52 pm
You need to go into the Internal Preferences in Vegas. Do this by holding down the Shift key and then go Options - Preferences. Click on the Internal button at the top right. Once in there, type closed in the search bar at the bottom, double-click and change TRUE to FALSE in the Value box, press OK and you're done. Restart Vegas and you won't get that message any more :)
Linda O'Connell
on Jan 14, 2015 at 5:30:36 pm
You are awesome. Thanks! :)
Mike Kujbida
on Jan 14, 2015 at 5:47:15 pm
You're welcome Linda. Glad I could help.
