Sony Vegas pro 13: "Render as" issues
COW Forums : VEGAS Pro
Traf Pepe
on Jan 2, 2015 at 12:13:57 pm
Hi there,
So i'm experiencing a weird problem with the render.
Before anything, it is important to note that it did always work perfectly but since today, it is not.
So I'm working on a video and, to check that the transitions are good, i selected from the begening till the 2nd minute to render as the final video.
The render goes on and when it is finished i have the little noise saying it is over.
I then have the choise between "Open" / "Open Folder" / "Close".
But the "Open" button is grey...
And when I click on "Open Folder", i have no vidéo, just the .tmp file...
When I shorten the selection for the render, then i have a video file...
Any ideas on what it might be?
After some tests, i also found those two weird facts:
If i stay under 2min, it works.
Over 2mins, it doesn't work.
If I change folder, it works couples of time and then it doesn't...
Thx alot
© 2018 All Rights Reserved
