Need keyboard shortcut for creating space between events in timeline.
COW Forums : VEGAS Pro
Mithun Kumar
on Jan 1, 2015 at 6:21:05 pm
Hi Need help with sony vegas pro. I need the keyboard shortcut to create space between two events after pressing the keyboard shortcut "S". Right now i am using mouse but its taking a lot of time.
This is to cut a movie into pieces and understand how shots are arranged.
Graham Bernard
Re: Need keyboard shortcut for creating space between events in timeline.
on Jan 1, 2015 at 9:09:58 pm
Intriguing.
G
Mithun Kumar
on Jan 2, 2015 at 4:18:01 am
G doesnt work :(
Matt Carlson
on Jan 2, 2015 at 2:41:37 am
Off the top of my head I do not know of any keyboard shortcut that adds space. I have, however, added what you needed to my Vegas Black Tools extension. I originally had these options that all can be assigned shortcut keys
Split Delete Left
Split Delete Ripple Left
Split Delete Right
Split Delete Ripple Right
After reading your post I added
Split Add Space
Split Add Space Ripple
Send me an email to blackstingproductions@gmail.com if you are still in need of this help and will give you the Black Tools extension.
David Eon
on Jan 8, 2015 at 4:25:04 am
Set a custom keyboard key (under Options dropdown>Customize Keyboard)
In the search box type Trackview.Nudge.RightByFrames,
In the Middle box Select Trackview.Nudge.RightByFrames
In the bottom box type whatever key you want to use to create your space ( I use Trackpad 9 for Right and Trackpad 7 for Left but it's whatever works for you)
Click the add button.
Now you can use that button on your keyboard to move your clip one frame at a time. Or press it as many times as you need to depending on how big of a space you need (30 frames = 1 second). Use the autoripple (Ctrl +L) to nudge the entire rest of the project if you need to.
I hope that helps. DavidEon
