iphone5 slow-mo?
COW Forums : VEGAS Pro
Doug Jackson
iphone5 slow-mo?
on Dec 25, 2014 at 3:48:49 pm
Seems to play a regular speed when dropped onto timeline. But Properties->General (and MediaInfo) say its 120 FPS.
So, is the trick to slow the playback rate in the event properties?
Which then, because of the higher framerate, you can slow much more without blurring?
Regards,
--Doug
John Rofrano
Re: iphone5 slow-mo?
on Dec 25, 2014 at 7:44:01 pm
[Doug Jackson] "So, is the trick to slow the playback rate in the event properties?"
Yes. Vegas Pro will always play footage at the frame rate of the project. If you want to create slow motion you need to change the playback rate of the event.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Doug Jackson
on Dec 26, 2014 at 4:10:34 pm
Thanks, John.
John Rofrano
on Dec 26, 2014 at 7:08:30 pm
You're welcome Doug.
~jr
