Volume drops while JKL scrubbing at any speed other than 1x
COW Forums : VEGAS Pro
James Kelley
on Dec 22, 2014 at 11:01:41 pm
Google has brought me to CreativeCow on many occasions and I thank you all for being a helpful community in the past :) I wasn't able to find any existing discussions on this particular topic, so this will be my first post here :)
This is what I've noticed:
Volume during 1x playback speed: -4db
Volume during any other speed: -22db
Test method: 1 second of dialog on loop
Software: Movie Studio Platinum 12
I assume this is normal, but is there any way to get consistency?
Graham Bernard
Re: Volume drops while JKL scrubbing at any speed other than 1x
on Dec 23, 2014 at 8:33:22 am
[James Kelley] "Volume drops while JKL scrubbing at any speed other than 1x"
I've tested in SVP6, don't have SVP12, sorry James can't repro. No drop in Audio Level.
Eh, is it possible to link a Keyboard shortcut to Audio Level Change AND the JKL speed keys?
Grazie
James Kelley
on Dec 23, 2014 at 9:39:14 am
Thanks for the reply Graham. I don't think it's possible to customize shortcuts in Movie Studio 12.
I figured out what's happening though-- it's simply not processing my VOLUME audio event FX.
I'll contact Sony support and see if they have a solution.
Graham Bernard
on Dec 23, 2014 at 10:17:09 am
[James Kelley] "I figured out what's happening though-- it's simply not processing my VOLUME audio event FX."
Clever - How did you discover that? Are you using an external AUDIO card needing ASIO drivers?
Grazie
James Kelley
on Dec 23, 2014 at 10:39:03 am
Simply using audio from my motherboard :)
I figured it out when I went back in and wasn't having the issue anymore. Then I realized I was playing a different section than before, so I tested it on the original section, and the levels dropped as expected. At first I thought it was because the file was a different video container, but then I noticed one had event fx and the other didn't.
P.S. It actually ignores all the Audio Event FX, not just Volume.
