Best file format to convert for editing in iMovie for a Mac
COW Forums : VEGAS Pro
Don Smith
on Dec 18, 2014 at 9:32:47 pm
I have someone who wants me to capture footage from an 8mm camera and convert it to a format she can copy to her Mac and edit in iMovie. I can capture directly from an 8mm camera and create an AVI file. I'm using Vegas Pro10 and I'm thinking convert the AVI to QuickTime7 (.mov). I'm wondering if I should use the 3 Mbps Video Template? I'm thinking Default (uncompressed) would make a huge file size, right? I need to burn the .mov to a data DVD for her to load in her Mac to work with.
Or...should I render it to a .mp4 file for her iMovie edit project instead of Quicktime? If so, what template? Default?
John Rofrano
Re: Best file format to convert for editing in iMovie for a Mac
on Dec 18, 2014 at 10:13:37 pm
[Don Smith] "Or...should I render it to a .mp4 file for her iMovie edit project instead of Quicktime? If so, what template? Default?"
I would rendering using Sony AVC with the Memory Stick SD NTSC - 6256 Kbps template assuming you are capturing to DV AVI. That can easily be imported into iMovie and should give you good quality with a reasonable file size.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Don Smith
on Dec 19, 2014 at 7:35:15 pm
Thanks John, I'll give that a try.
