Remove only loud noises.
COW Forums : VEGAS Pro
John Last
on Dec 18, 2014 at 1:37:39 pm
I searched for tutorials but all are to remove background noise, and my video requires background noise but sometimes the wind in the micro very loud.
I have tried several plugins but I have not made it, I want to do exactly the opposite that makes the Noise Gate plugin, instead of eliminating all sound below x decibels, from above.
John Rofrano
Re: Remove only loud noises.
on Dec 18, 2014 at 2:39:46 pm
You want to use a compressor. Either the Track Compressor (which is on every track by default) or the Wave Hammer plug-in. Wave Hammer has a Volume Maximizer that also has the ability to Limit the volume to a given dB setting. For example if you set the output max to -10dB you will never get any audio the goes above -10dB. The Threshold setting determines when this kicks in (i.e., how soft a sound gets affected).
~jr
http://www.johnrofrano.com
http://www.vasst.com
John Last
on Dec 18, 2014 at 3:58:40 pm
I have alredy tried, I am not able to do it...
With NoiseGate it's so easy, it can be that hard to put a db limit.
Pd: I think I made it, with EspressFX Dynamics.
John Rofrano
on Dec 18, 2014 at 4:28:09 pm
[John Last] "I have alredy tried, I am not able to do it..."
Here is what you need to do:
  1. Add Wave Hammer Surround to the track (or master audio fader)
  2. Select the Volume Maximizer tab
  3. Set the Output Level to -12dB
That's it! No audio will exceed -12dB. It doesn't get any easier than that.
~jr
