Panning larger resolution event within a project
COW Forums : VEGAS Pro
Stewart Bourke
on Dec 17, 2014 at 9:21:15 pm
SVP12 Pro.
I thought this would be easier, but I obviously some something simple, wrong.
I have a project with the properties set to 1280 x 720.
I have several events containing media at this resolution.
I have one media clip of 1920 x 1080, and I want to place this on a track and 'move around' within the event so that at any stage I have a 'window' of 1280 x 720 onto the clip. The clip contains green-screen footage of birds flying and they are far too large, so I want to zoom out on this track so they are much smaller.
The problem is that no matter what I do the pan/crop window does not appear to allow me pan around the track - it seems to treat it as 1280x720.
I have tried unsetting the 'maintain aspect ration' and 'stretch to fill frame'. I have also tried track motion and it all gives the same result.
Ideally I would like to zoom out on the 1920 clip so it is 1280, thus making the birds in the clip much smaller...
I have confirmed the footage is definitely 1920x1080
I have followed various tutorials and none of them seem to address this specific issue.
Many thanks for any pointers on how to achieve this.
STBO.
Tyson Onaga
Re: Panning larger resolution event within a project
on Dec 17, 2014 at 10:33:51 pm
Your Track Motion keyframe should be 1280x720.
Your P/C keyframes can be between 1920x1080 down to 128x720, probably maintaining the 16:9 aspect ratio.
Vegas will then scale the Event to 1280x720 at the x-y-z location specified by your Track Motion keyframe.
Stewart Bourke
on Dec 17, 2014 at 11:29:20 pm
Tyson,
Thanks for the info. To be honest I am a little lost.
When you say 'Your Track Motion keyframe should be 1280x720.' what do you mean - do you mean the width/height settings? What am I keyframing?
Also, when I set the P/C size to 1280/720 the image is now much bigger.
Apologies - but I have no idea where to start with what you are saying - what am I keyframing, and when?
STBO
John Rofrano
on Dec 18, 2014 at 1:17:49 am
[Stewart Bourke] "Apologies - but I have no idea where to start with what you are saying - what am I keyframing, and when?"
Go into Pan/Crop for the media that is 1920x1080 and set the width to 1280 and height to 720 and you will have the Pan window that you are after.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Tyson Onaga
on Dec 18, 2014 at 8:26:32 am
Yes, the width and height should be 1280x720. If this matches your project settings, then that Track uses the entire display region. Eg., if you made it 854x480 (also 16:9), then you could position it within your (larger) 1280x720 display region.
Your project ix 1280x720.
Your Event is 1920x1080.
On your 1280x720 Track ...
If you put a 1280x720 P/C keyframe on that Event, then that should be shown, pixel for pixel.
If you put a 1600x900 P/C keyframe on that Event, then that should be shown (scaled down to 1280x720).
If you put a 1920x1080 P/C keyframe on that Event, then the entire Event should be shown but scaled down to 1280x720.
Stewart Bourke
on Dec 18, 2014 at 10:14:12 am
Folks,
Thank you all for the replies. it has helped me greatly understand what is going on.
having worked through all the answers and experimented I see now the relationships and realise I was making things far too complicated for myself by over-thinking it.
STBO.
