i need sutiable graphic card --?
COW Forums : VEGAS Pro
harry singh
on Dec 10, 2014 at 7:11:05 pm
hi just recent i upgrade my machine into i7 from i3. now i have
i7 4770 prossesor.
gigabyte Technology Co., Ltd. H97M-D3H--- mother board
8 gb kingston ram
750 ti msi graphic card
my problem is that imy preview is very lagging if i add litle heavy effect. without effects it runs smooth on hd 1920x1080 p clips .
now plz guide me which card i should to buy for only view play back , beouse i always use cpu for rendring . but i have problem with play back .
regards
harry
Regards
harry
John Rofrano
Re: i need sutiable graphic card --?
on Dec 10, 2014 at 9:13:36 pm
The general consensus is that AMD Radeon cards are better for accelerating timeline playback than NVIDA cards. Something like an AMD Radeon R9 290x would probably help. Buy it from someplace that accepts returns if it doesn't. ;-)
~jr
http://www.johnrofrano.com
http://www.vasst.com
Sorin Nicu
on Dec 10, 2014 at 11:40:54 pm
Before you throw money at the "problem" ($350-380 is what John recommends), you can check to see if all the settings are correct and if the card is actually used during preview.
To see the actual GPU utilization, I recommend the free GPU-Z software.
harry singh
on Dec 11, 2014 at 10:14:29 am
thnx for your reply
ibefore i checked 2 amd cards
1 amd radeon saphire x7 265
2. amd hd 7500
but these cards are very bad permorence rather thn nvidia 750 ti msi
now i am trying to exchange my card with gtx 560
what you think gtx 5 series is very suitable with vegas pro 12
i check these on forums .
any comment is valuable .
regards
harry
Regards
harry
John Rofrano
on Dec 11, 2014 at 4:45:45 pm
[harry singh] "what you think gtx 5 series is very suitable with vegas pro 12 "
I don't think I was clear. NVIDIA cards do not work as well at timeline acceleration as AMD cards do. This is because NVIDIA uses CUDA and Vegas Pro uses OpenCL and AMD uses OpenCL too. So an NVIDIA card is not going to perform as well as a comparable AMD card for timeline playback with Vegas Pro because it's OpenCL implementation is not as good as AMD's OpenCL.
~jr
Sorin Nicu
on Dec 11, 2014 at 8:50:40 pm
nVidia cards have OpenCL compatibility too... I even posted somewhere a link to a OpenCL benchmark that had various cards tested.
But without looking into his actual GPU usage, is just throwing money away, hoping to be lucky...
John Rofrano
on Dec 12, 2014 at 1:55:28 am
[Sorin Nicu] "nVidia cards have OpenCL compatibility too..."
That's what I said. Here is my exact quote:
The words " it's OpenCL implementation is not as good as AMD's OpenCL" implied that while NVIDIA does have OpenCL support... it's not as good as AMD's. Sorry if it was confusing. The second "it's" refers to "NVIDIA's".
~jr
Sorin Nicu
on Dec 11, 2014 at 8:56:22 pm
[harry singh] "what you think gtx 5 series is very suitable with vegas pro 12"
Since it is a Fermi generation nVidia, it will work better with MainConcept CUDA encoder (rendering). Newer cards are not supported.
However, the timeline acceleration might be better with the 750Ti.
Do you have slots to keep both of them in the system? Because you can select what to use for timeline and what for rendering.
harry singh
on Dec 12, 2014 at 8:25:36 am
thnx for your feed back
but actual in svp 12 there is no setting for gpr optimization
https://i1.creativecow.net/u-upload.php
so every time i have to off my gpu acceleration while working on timeline
if i select my card there the preview very lag...
and about amd i told u i try amd radion saphire 7x 865. and hd 7500
but they are very worse
i am using vegas pro suit build 394 latest update
so i heard veags pro 13 has updation with new nvidia cards. so i download trial vegas pro 13
in this i found that tab " optimziation" for graphic card.
but its previeiw also lagging but not very much. but its lagging while i add effects. without effects its run smooth.
so i should follow.
upgrade my nvidia
or if amd . which card amd will support vegas pro suit 12?
Regards
harry
harry singh
on Dec 12, 2014 at 5:14:58 pm
so i should follow.
upgrade my nvidia
Regards
harry
John Rofrano
on Dec 14, 2014 at 1:50:39 am
[harry singh] "so i should follow. upgrade my nvidia or if amd . which card amd will support vegas pro suit 12?"
If you want smoother timeline playback you will get the best results from an AMD card. The Radeon R9 290x seems to be the one people are buying for this.
~jr
Steve King
on Dec 14, 2014 at 5:43:14 pm
I'm getting excellent results with the older, slightly less expensive Sapphire R9 280x.
Steve
Steve K
Full time writer/director
Pt. Time Video Editor
harry singh
on Dec 11, 2014 at 11:49:06 am
this is my gpu specifiations taken by gpu z application.
and in my vegas under preview setting tab there is no
any setting for optimizes graphic card performence.. in svp 12
Regards
harry
John Rofrano
on Dec 11, 2014 at 4:49:38 pm
That's the wrong link. You're supposed to paste the link that you get after the upload:
~jr
harry singh
on Dec 12, 2014 at 8:27:13 am
sorry the embede code
Regards
harry
