Record Arm
COW Forums : VEGAS Pro
Roger Bansemer
Record Arm
on Dec 10, 2014 at 5:33:11 pm
I've been doing some voice overs using "Arm for Record"
In the past a box has always come up telling me where the audio will be filed. Now that doesn't happen anymore and it defaults to a documents directory which is not where I want it.
How do I arm for record and have it ask me where I want the audio to reside again like it use to?
Roger
Roger Bansemer - PaintingAndTravel.com
Russ Froze
Re: Record Arm
on Dec 12, 2014 at 6:16:59 am
HI, I'm sorry I don't know how to reset to the default popup that asks where to put the file. I do know that the recorded files folder setting can be accessed via the project properties under the audio tab half way down is the "recorded files folder"
Russ Froze
Mark Barton
Re: Record Arm
on Dec 15, 2014 at 10:15:26 pm
You must have checked the box not to prompt. I see the setting in the Internal settings tab that you can access by pression the SHIFT key while choosing Options from the Tools menu. I used record for the search filter and circled the entry in the screenshot. Change the setting from TRUE to FALSE.
Russ Froze
Re: Record Arm
on Dec 16, 2014 at 9:12:26 am
Thanks Mark, it is nice to have the answer to these simple little things. Especially since it is soooo easy to to dismiss the prompt by accident.Russ Froze
