Unmanaged Exception (0xc0000005)
COW Forums : VEGAS Pro
Mika Périgord
on Dec 2, 2014 at 10:34:18 am
Problem Description
Application Name: Vegas Pro
Application Version: Version 13.0 (Build 428) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Fault Address: 0x0000000000000000
Fault Offset: 0x0000000000000000
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Process Version: Version 13.0 (Build 428) 64-bit
Process Description: Vegas Pro
Process Image Date: 2014-11-24 (Mon Nov 24) 22:12:34
john bolton
Re: Unmanaged Exception (0xc0000005)
on Dec 4, 2014 at 1:14:10 pm
Someone else had this problem.. They changed the name of the media content folder and try opening the project. It got to 25% then said it can't fine a media file so I told it the location of the file it opened. Vegas asked if I wanted to open all the media in this location, I said yes. Then it all worked................ Worth a try
© 2018 All Rights Reserved
