Sony Vegas pro 13 doesn't recognize file
COW Forums : VEGAS Pro
Dule Bajin
on Nov 22, 2014 at 4:27:33 pm
Hi everyone.
I am new here, so, please forgive me if I did something wrong, also English is not my native language.
I am working for a while on some movie....
After I installed Vegas pro 13, one of the files from previous project simply disappeared. At that place (where the video detail is) I get only black field in the preview now - also if I try to render the file - in final video I get just a black hole again.
It's a .MOV video file.
Resolution 1500X1002
Size 57,2 MB
-First I thought maybe is problem with file format, so I converted video from MOV to MP4, but no change...
Interestingly when I was converting file first time I accidentally converted it in a different resolution - then Vegas registered video.
After i converted again in original resolution - video disappeared again.
Which is craziness! I don't understand that. Since when Vegas doesn't import specific resolutions????
Video is not standard resolution though, but, still, it was visible in older versions of Vegas. It's just a 3D flag video detail created in Adobe After Effect, so I could use it in this movie in Vegas.
I can't create a new detail now in different resolution and go again through whole setup and positioning of that detail in the video because it is very complicated.
Very frustrating!
I will be very grateful for any advice.
Thanks in advance.
John Rofrano
Re: Sony Vegas pro 13 doesn't recognize file
on Nov 22, 2014 at 7:42:51 pm
What codec does the video use? Can you open it in the QuickTime Player? If so, press Ctrl+I to bring up the inspector and post a screen shot of the details.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Patrick Paine
on Apr 25, 2015 at 7:06:09 pm
My 1st reach out - in desperation of course:
I have similar issue with my finished 7 month edit (!!) - v13 will not open .mpg or .mov files, and consequently will not open my precious .veg file...
Won’t even show up in Vegas explorer window!
>SAME issue in v11 & I believe in Movie Studio.
>These files will open in any player just fine
> Already tried the compoundplug.dll file name change/unchange - no difference.
Thanks for any suggestions you may have,
Patrick
Steve Rhoden
on Nov 22, 2014 at 9:06:52 pm
That is indeed strange, do you still have the After effects project
for this particular video?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Dule Bajin
Re: Sony Vegas pro 13 doesn\'t recognize file
on Nov 22, 2014 at 9:22:26 pm
Sorry guys, I am at work now. I can't do much... answering from my phone now.
Yes, I do have after effect project for that video file.
And yes, I can play the video in quick time and all other players....
Also I did converted mov file into mp4 file, and still Vegas doesn't recognize it.
Although I have many other mov and mp4 files already included into the project and all works properly.
Just this particular file dissappeared.
And, as I said, when I was converted it to mp4 first time I didn't check "keep original size" option and I got different resolution and that video was visible in vegas.
when I did it again in original resolution 1500x1002 it dissappeared again.
very weird.
when I go home I'll give you more infos.
Steve Rhoden
on Nov 24, 2014 at 12:11:45 pm
Just open up back after effects and render out that project again
in a quicktime format and in the resolution the Vegas project is in..
Dule Bajin
Re: Sony Vegas pro 13 doesn\\'t recognize file
on Nov 24, 2014 at 3:23:03 pm
Oh, but that is not going to solve the problem.
If I render now that video detail in different resolution it will completely change the position in the video project.
It's a 3d flag which I made in after effect. That flag is resized in my vegas video project and it's moving there following some other details in the video. It's moving complicated - literally I was positioning it in each frame.... I needed few days of work to acomplish that.
If I render now that detail again in another resolution I will need to do everything again....
That's why I said I can't go again through all the settings.
Everything worked normally before. What happened now? That's very weird.
Mike Kujbida
on Nov 24, 2014 at 4:27:31 pm
Render it in that same resolution but as a series of PNG images with transparent background.
When you get back into Vegas, import it as an image sequence and everything should line up just fine.
No codec issues to worry about :-)
Dule Bajin
on Nov 24, 2014 at 4:34:17 pm
Oh ok ok.
Sounds good. I'll try that.
Mike Kujbida
on Nov 24, 2014 at 4:39:45 pm
I render out that way from After Effects all the time so I know that it does work.
Let us know if you need help with the image sequence once in Vegas.
Dule Bajin
on Nov 24, 2014 at 4:43:58 pm
Help would be good. I think I never done that before.
Mike Kujbida
on Nov 24, 2014 at 5:09:02 pm
Render the image files from After Effects to a specific folder.
Once that's done, start up Vegas, go File - Import, browse to your AE folder, click on the first image and then click the Open Still Image Sequence box at the bottom of that window. Make sure that the range is the same as what you rendered out. Click Open which will bring up a new window. Make any changes in this new box if you have to and then press OK. The file will now show up in your Project Media tab. Drag it to your timeline and play it :-)
Steve Rhoden
on Dec 1, 2014 at 11:17:52 am
Any Luck?
John Rofrano
on Dec 2, 2014 at 11:37:47 am
[Steve Rhoden] "Any Luck?"
Luck has nothng to do with it... it's all about Skill ! (...ok, maybe a little luck doesn't hurt) :-D
~jr
Dule Bajin
on Dec 2, 2014 at 10:07:11 pm
I will do that tonight.
I was on business trip - very busy period.
I will try today and let you know
Dule Bajin
on Apr 25, 2015 at 6:34:36 pm
Sorry guys for very late answer. It is kind a disrespectful but i wasn't able to do anything before.
I just wanna tell you that PNG sequence worked just fine. It is very simple and logical solution.
Thank you very much for help.
....and Sony vegas should also think about this strange glitch/problem what ever it is.... because it is very strange.
