Paint brush effect
COW Forums : VEGAS Pro
Roger Bansemer
Paint brush effect
on Nov 18, 2014 at 5:03:40 pm
I'm looking to do a segment where I have a paint palette and digitally have it look like paint brush marks are removing some of the paint to expose another event underneath it. Sort of like paint brush swipes back and forth to expose the background.
Any ideas as how I might accomplish this?
Roger
Roger Bansemer - PaintingAndTravel.com
Mike Kujbida
Re: Paint brush effect
on Nov 18, 2014 at 5:17:27 pm
Roger, I can't remember if you have Photoshop but if you do you can export your segment as a series of frames, bring them into Photoshop and use a custom brush to do what you want.
You'll find a whole bunch of free ones here.
http://www.creativebloq.com/photoshop/free-photoshop-brushes-11121140
Graham Bernard
on Nov 18, 2014 at 5:43:07 pm
Roger? Didn't I produce something for you, like this?
Eh . . . ?
G
Graham Bernard
on Nov 18, 2014 at 6:32:28 pm
Here's my feeble attempt:-
Roger Brush Strokes
I motion grabbed using Fred Baumann's s/w.
G
Frederic Baumann
on Nov 30, 2014 at 10:09:48 pm
Thanks Graham :-)
Frédéric
FBmn Software: Professional GPU-powered plug-ins to fix White Balance and Exposure issues in a few clics.
Color-matching made easy with the ColorMatch plug-in.
Want to learn on Sony Vegas Event Pan/Crop tool? Watch my tutorial.
Or about Keyframes? Watch this one. French version here.
Tyson Onaga
on Nov 19, 2014 at 1:19:34 am
Roger,
You might need a paint brush/stroke animation file. Digital Juice's Compositor Toolkit #2 has some Paint FX. There's some at http://videohive.net/
Track 1 - Animation clip; add Sony Mask Generator (Luminance)
Track 2 - your "revealed" clip/photo
Track 3 - your background
Make Track 2 a child of Track 1.
Change Track 1's Compositing Mode to Multiply.
If you want just a portion of the brush stroke to be used, then add a Mask to the Event on Track 1 (the animation clip).
Edward Troxel
on Nov 19, 2014 at 9:01:18 pm
Why not just use the "Sony Gradient Wipe" transition and then create you a gray-scale (or find a gray-scale) image that would simulate the "painting on"?
Edward Troxel
Graham Bernard
on Nov 19, 2014 at 9:15:56 pm
[Edward Troxel] "Why not just use the "Sony Gradient Wipe" transition and then create you a gray-scale (or find a gray-scale) image that would simulate the "painting on"?"
Wouldn't that just create a Static Brush Stroke? My treatment lends movement to the Brush Stroke.
Grazie
Tyson Onaga
on Nov 19, 2014 at 10:09:34 pm
If Roger really wants the look of a paint brush (ie, bristles) look, then he really needs an animation file.
There's one here:
Use a clip like that on Track 1 with the Mask Generator and Track 2 will look like it was "painted" on top.
https://www.dropbox.com/s/ulkyc9p1pquamyi/Image1_paintStrokeComposited_over...
Edward Troxel
on Nov 20, 2014 at 5:55:01 pm
Grazie, just presenting options. With the proper image, it would be easier to apply as a transitions and would not need multiple tracks and composition settings.
Edward Troxel
Graham Bernard
on Nov 20, 2014 at 9:10:38 pm
[Edward Troxel] "Grazie, just presenting options."
Sure, Edward I understand, I do this all the time. However it was this below that makes me think Roger wants Brush "movement", not a simple static transition through a "brush" mask:-
[Roger Bansemer] " . . . . look like paint brush marks are removing some of the paint to expose another event underneath it. Sort of like paint brush swipes back and forth to expose the background."
Grazie
