DVD made with architect and Vegas won't ffwd or rewind
COW Forums : VEGAS Pro
scott sullivan
on Nov 15, 2014 at 4:08:29 pm
Does anyone know what would cause this? I have a DVD that plays great and looks great, but won't fast forward or rewind properly. The audio seems to pick up but the screen stays static.
These are my settings:
Any suggestions?
scott sullivan
Re: DVD made with architect and Vegas won't ffwd or rewind
on Nov 15, 2014 at 6:24:47 pm
Lowering the BR fixes it, but my first settings looked a whole lot better. Any ideas?
John Rofrano
on Nov 16, 2014 at 11:08:15 am
Are you sure DVD Architect isn't re-encoding that video? DVD's do not support progressive video at 29.97 fps so that template is not DVD compatible. The only valid formats for DVD's are 60i, 50i, & 24p.
~jr
http://www.johnrofrano.com
http://www.vasst.com
scott sullivan
on Nov 17, 2014 at 6:10:48 pm
Ok so should I take out the progressive setting and set to 24 p instead?
scott sullivan
on Nov 17, 2014 at 6:13:47 pm
Or maybe more simply would be to ask how should I change the settings to best fit DVD? I've been successfully using the following settings but the result leaves a little to be desired in terms of quality:
John Rofrano
on Nov 18, 2014 at 1:56:57 am
[scott sullivan] "Or maybe more simply would be to ask how should I change the settings to best fit DVD?"
Use the built-in DVD Architect templates and don't modify them. Sony has already provided the correct templates. All you need to do is use them.
~jr
Heinrich Himmel
on Nov 18, 2014 at 1:12:49 pm
As John Rofrano says, use the DVD Architect templates. If you want to change anything, change the bitrate settings:
Enable 2 Pass (this doubles encoding time but increases quality)
Minimum bitrate to 2,250,000
If your total length in the disc is less than 76 minutes, use Constant bitrate of 7,550,000. Anything 76 minutes and longer, use 2 pass VBR with the appropriate average bitrate for the length.
