Render settings
COW Forums : VEGAS Pro
Thegarage Live
Render settings
on Nov 14, 2014 at 8:10:10 pm
I'm filming a music TV show using 4 canon 5d DSLR cameras then editing on sony vegas 10. I've received these tech specs and wondered what you guys thought would be my best render settings? Any info would be appreciated.
QuickTime/AVI/MXF
1920x1080
25FPS
48 K Stereo Mix
Bitrate above 8000K
John Rofrano
Re: Render settings
on Nov 15, 2014 at 11:13:30 am
It's interesting that those specs say nothing about what codec to use. It just lists 3 containers that could have anything in them.
I would render to Sony MXF using the HD EX 1920x1080-50i template. Then press the Custom... button and change the Field Order to Progressive. That will give you very high quality 35Mbps video which is well above their 8Mbps limit.
If that file is too big, use Sony AVC with the Internet 1920x1080-25p template and when the render is finished, rename the .mp4 file to .mov and they will be none the wiser. That will give you a 16Mbps video that is also well above their 8Mbps minimum.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Thegarage Live
Re: nder settings
on Nov 17, 2014 at 5:55:50 am
Thank you.
My only issue with MXF is I can't check the quality as I can only playback through vegas. I've sent them some test footage with those settings.
Thanks again
John Rofrano
Re: nder settings
on Nov 17, 2014 at 1:10:26 pm
[Thegarage Live] "My only issue with MXF is I can't check the quality as I can only playback through vegas. "
Download Sony's XDCAM Viewer. Then you can preview outside of Vegas Pro.
~jr
Mike Kujbida
Re: nder settings
on Nov 17, 2014 at 2:07:22 pm
I use the Sony XDCAM viewer but, in a pinch, VLC will play MXF files.
