System low on memory.
COW Forums : VEGAS Pro
Will Kee
on Nov 10, 2014 at 10:09:41 pm
Vegas Pro 12, latest build.
Rendering out an uncompressed MOV to a HD that has plenty of TB of space.
16GB RAM on computer. 5GB used when trying to render said project.
Why?
Will Kee
Re: System low on memory.
on Nov 10, 2014 at 10:11:34 pm
And now the whole program crashes and exits when I try.
Steve Rhoden
on Nov 10, 2014 at 10:37:03 pm
Could you render out following this same method before?
Wondered if you recently updated Windows?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Will Kee
on Nov 11, 2014 at 12:46:37 pm
Yes.
I have not updated windows for years.
Dave Osbun
on Nov 11, 2014 at 1:03:43 pm
Could be a few reasons: programs starting up at system boot-up, bad RAM chip, maybe something else.
Start by running MSCONFIG (type that in Windows run box), go to 'startup' tab, uncheck everything except your antivirus/security software. Reboot. Then try to render.
John Rofrano
on Nov 11, 2014 at 4:16:42 pm
[Will Kee] "16GB RAM on computer. 5GB used when trying to render said project."
That won't help you. Vegas Pro uses a 32-bit version of QuickTime so it can't see more than 2GB of memory. You will never get uncompressed QuickTime to work with Vegas Pro. Trust me on this one... been there... done that... it always blows up!
Why are you rendering uncompressed? Why not use a digital intermediary like Avid DNxHD? If you really need uncompressed in QuickTime, I recommend that you render to an uncompressed AVI file and then use another program like QhucikTime Pro to make an uncompressed QuickTime file.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Will Kee
on Nov 11, 2014 at 4:23:06 pm
I'm rendering uncompressed because I am delivering a video I edited, which will be transcoded (by someone else) to various requested TV formats etc.
I might give them an uncompressed AVI and see if that's acceptable.
Will Kee
on Nov 11, 2014 at 8:38:06 pm
It's also worth noting that I'm exporting a 2K project. (2048 x 854 pixels).
John Rofrano
on Nov 12, 2014 at 2:26:50 am
You should see if they will accept Avid DNxHD. This is visually lossless and will produce much smaller files than uncompressed. Also see if they will accept Sony MXF HD422 50Mbps. These are very high quality.
~jr
Will Kee
on Nov 12, 2014 at 11:52:01 am
I seem to having issues rendering out any MOV (dnxhd, animation, motion jpeg etc)
John Rofrano
on Nov 12, 2014 at 7:42:08 pm
[Will Kee] "It's also worth noting that I'm exporting a 2K project. (2048 x 854 pixels)."
Hmmm... it may be the fact that your project is 2K. Can you render it in smaller sections or does it stop immediately?
[Will Kee] "I seem to having issues rendering out any MOV (dnxhd, animation, motion jpeg etc)"
Can you render to Sony MXF? Let's make sure that it's QuickTime and not something else stopping the render.
~jr
