Audio limiter plugin for Vegas?
COW Forums : VEGAS Pro
Mateusz Duzinkiewicz
on Nov 2, 2014 at 5:37:38 pm
Hi.
Any of You know any working limiter for Vegas? Compressor is OK but when exporting for public broadcaster I have to literary cut of the sound when it reach -6dB and compressor cannot do the trick so that's why limiter was invented but non of them in Vegas and also hard to find working plugin for it to. I do not want to use external programs I want master my sound in Vegas, any solutions?
Montage.pl
Russ Froze
Re: Audio limiter plugin for Vegas?
on Nov 2, 2014 at 9:33:45 pm
Hi, in the track compressor is there not a preset ** [Sys] Limit levels to -6 (hard limiter)** ? This has done well for me in the past. IF you have Pro 13 it comes with iZotope nectar.
Russ Froze
John Rofrano
on Nov 3, 2014 at 12:16:37 am
[Mateusz Duzinkiewicz] "I have to literary cut of the sound when it reach -6dB and compressor cannot do the trick so that's why limiter was invented but non of them in Vegas and also hard to find working plugin for it to."
Try Sony Wave Hammer Surround. The Output Level on the Volume Maximizer acts like a Brick Wall Limiter. Set it to -6dB and nothing will be louder than that. Use the Threshold to compensate. In other words, place a -20dB test tone on the timeline, set the Output Level to -6dB and lower the Threshold until the test tone reads -20dB again.
~jr
http://www.johnrofrano.com
http://www.vasst.com
on Nov 4, 2014 at 8:35:39 am
[John Rofrano] "Try Sony Wave Hammer Surround. The Output Level on the Volume Maximizer acts like a Brick Wall Limiter. Set it to -6dB and nothing will be louder than that. Use the Threshold to compensate. In other words, place a -20dB test tone on the timeline, set the Output Level to -6dB and lower the Threshold until the test tone reads -20dB again."
Yes, it did the trick. Thank You.
John Rofrano
on Nov 4, 2014 at 12:16:41 pm
You're welcome. Glad you got it working.
~jr
on Nov 5, 2014 at 4:42:10 pm
One more thing - the most important, if You want to use Wave Hammer as limiter, then You need to check "bypass" at compressor selection, other way it will not work.
John Rofrano
on Nov 5, 2014 at 8:38:39 pm
[Mateusz Duzinkiewicz] "You want to use Wave Hammer as limiter, then You need to check "bypass" at compressor selection, other way it will not work."
Why do you have to bypass the compressor? The Volume Maximizer comes after it so it will limit whether the compressor is bypassed or not? Or were you saying to be careful not to add unwanted compression?
~jr
on Nov 6, 2014 at 9:04:41 am
Yes, You are right, it work both ways :)
John Rofrano
on Nov 6, 2014 at 11:38:49 am
Yes but you make a good point. If you just want to limit and not compress, make sure you bypass the compressor.
~jr
