Sony Vegas "The Following file could not be found in the specified location"
COW Forums : VEGAS Pro
Rina Sims
on Oct 29, 2014 at 8:04:27 pm
I recently moved around a lot of my files and I need to specify a new location or replacement file.
What I would like to know is is there a way to expand the previous locations file path when finding a replacement location? It says this at some point, "\Sea...\" The problem is with the cut off on "Season".
Steve Rhoden
Re: Sony Vegas "The Following file could not be found in the specified location"
on Oct 29, 2014 at 9:51:56 pm
Yes you can, when it prompts you, select "Specify a new location" and click ok
and when that window pops up, you simply extend it by dragging the edges so
you can clearly see the full length of the file description.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Rina Sims
on Oct 29, 2014 at 11:48:18 pm
Thank you. That works. You just saved me a lot of time! :)
Steve Rhoden
on Oct 31, 2014 at 5:58:29 am
Glad i could help Rina. Good luck with your edits.
