Problem After Rendering Video
COW Forums : VEGAS Pro
Adriano Magnavita
on Oct 23, 2014 at 4:18:10 pm
Hey guys! I'm trying to render a vide in WMV 6Mbps 720 30p Video, but this keep happening:
The Video Settings are:
Mode: CBR
Frame rate: 29.970
Seconds per keyframe: 5
Video smoothness: 100%
How can I stop this? I'm using Vegas 12 Pro, but this never happened when I used 9 Pro. Thanks in advance
Aleksey Tarasov
Re: Problem After Rendering Video
on Oct 23, 2014 at 6:52:31 pm
Frame rate of original clips?
Adriano Magnavita
on Oct 24, 2014 at 2:24:04 am
Tha frame rate of the original clips is 30. However I just changed the frame rate in the video settings, but after rendering the problem still happens. It's a little faster though.
Graham Bernard
on Oct 24, 2014 at 4:04:50 am
Try something other than Windows Media - that's your WMV render, yes? Try MP4 or even AVI?!
Also, are you absolutely certain you don't have another "higher" track set with a lower Video Level? - I had to ask.
Grazie
