How would you fix this color problem in Vegas?
COW Forums : VEGAS Pro
scott sullivan
on Oct 22, 2014 at 9:57:57 pm
Shot some footage that was too bright. (see link to pic below)
What sort of correction can you use to make it look better?
thanks
Scott
Bob Peterson
Re: How would you fix this color problem in Vegas?
on Oct 23, 2014 at 2:43:12 pm
If you mean the guy on the right is too bright, I would use a color curve. The trick is to make the adjustment so that the bright things are darkened, but the darker things are not affected. I do this by taking a screenshot, and then use Photoshop to tell me where on the curve the target luminance is located. I can then set up the appropriate fixed point on the Vegas color curve, and pull the curve above that point down to darken the highlights. I do try to keep the curve as smooth as possible.
scott sullivan
on Oct 23, 2014 at 2:57:14 pm
Thanks Bob!
