Adding Transition Restores Deleted Frames
COW Forums : VEGAS Pro
Derek Brennan
on Oct 21, 2014 at 3:20:11 pm
I am a novice user of Vegas Pro 12 and have run into a problem with transitions. When I delete about 5 frames at the end of a clip using the split function with Auto Ripple on, the transition between the two clips plays correctly. However when I apply a transition (NewBlue Titler Pro 3.0 ) the previously deleted 5 frames are restored.
I would greatly appreciate any help to overcome this problem.
Derek
