AVI in Vegas (again?) =(
COW Forums : VEGAS Pro
Gaston Aragon
on Oct 12, 2014 at 9:40:00 am
Hi there,
oh yes, I was looking for this problem in this forum and googled it alot, but unfortunately nobody could help me.
I recorded a game with "action". It's generated in an avi container and here are the infos about the file:
[Video] ID : 0
Format : FICV
Codec ID : FICV
Duration : 3mn 12s
Bit rate : 75.1 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 60.000 fps
Bits/(Pixel*Frame) : 1.358
Stream size : 1.69 GiB (75%)
[Audio] ID : 1
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 00001000-0000-0100-8000-00AA00389B71
Duration : 3mn 12s
Bit rate mode : Constant
Bit rate : 24.6 Mbps
Channel count : 8 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : 192 KHz
Bit depth : 16 bits
Stream size : 565 MiB (25%)
Alignment : Aligned on interleaves
Interleave, duration : 10 ms (0.60 video frame)
When I put it in Vegas (12), only the video stream will show up. Audio doesn't. The strange - and for me not understandable - thing is: If I direct extract the audio with the program "super", the wav-file looks like this:
[Audio] Format : PCM
Duration : 3mn 12s
Bit depth : 16 bits
Stream size : 565 MiB (100%)
So.. am I crazy, or is it the exact same audio type/file/thing I got in the AVI-container of my video? Yes, it is I think. And now I can add this to Vegas and it works. Of course this workaround is really circuitous and also I think it must be possible to just add the AVI and it works.... somehow.
Why doesn't Vegas bring all the codecs with it so that you don't have a problem? I don't understand this. And I thought if my normal windows media player can playback the file.. then there must be a codec for that, right? Why doesn't Vegas use it then? =(
Can you help me?
Steve Rhoden
Re: AVI in Vegas (again?) =(
on Oct 12, 2014 at 8:36:24 pm
Remember AVI is a wrapper, meaning not all AVI's are the same. Whatever you
used to capture this AVI, uses a codec that Vegas does not interpret very well.
Therefore the workaround you have is what you gonna have to stick with, if
you gonna capture using that same device!
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
