BCC flicker fixer
COW Forums : VEGAS Pro
Enrique Orozco
BCC flicker fixer
on Oct 11, 2014 at 2:08:15 pm
I'm experiencing "vegas stop rendering" when using this (excelent) filter (in Vegas 12 pro) ... never used before... any alternatives or suggestions ? .. really need to fix one (long) take from a live event (flicker from fluorescent light)...
any advice would be greatly appreciated
Enrique Orozco R.
iDEA DigitalVideoStudio
John Rofrano
Re: BCC flicker fixer
on Oct 11, 2014 at 2:40:45 pm
Can you render in smaller section? Then put them all back together and render a larger file again to use in your project.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Enrique Orozco
on Oct 11, 2014 at 3:29:35 pm
... I'm going to try that... 5 mins. subclips will be OK ? what do you think ?
thanks in advance...
Enrique Orozco R.
John Rofrano
on Oct 11, 2014 at 9:41:20 pm
They only need to be small enough to not give an error. 5 minutes should be fine.
~jr
