Master Bus Fader Locks up Vegas
COW Forums : VEGAS Pro
Roger Woolnough
on Oct 10, 2014 at 7:31:21 am
In Vegas Pro 13 (build 373), I can move the master bus fader OK if no files or projects are open. But if anything is open, even just one audio file, when I try to move the fader, it may move slightly, then freezes. After that, I cannot make anything work; no menus or track controls, etc. The only exception I have found is that the project will play using the spacebar to start and stop. Then, I need to force-close Vegas using Windows Task Manager.
If instead of using the fader beside the level meter, I open the mixer window, and move the master bus fader in the mixer window, no problem. Then, when I close the mixer window, the fader attenuation in the main window correctly shows the change I made. So, this is a workaround for me, but I can't make it move directly.
Is this a bug, or am I missing something here?
Steve Rhoden
Re: Master Bus Fader Locks up Vegas
on Oct 10, 2014 at 3:51:29 pm
No, you are not missing anything Roger. It is a bug, but im not sure if
it will be addressed in the next update!
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Nigel O'Neill
on Oct 11, 2014 at 1:04:51 am
Roger/Steve, a workaround:
https://forums.creativecow.net/readpost/24/982596
My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Steve Rhoden
on Oct 11, 2014 at 10:48:42 am
I know about the workaround Nigel. Hoping its addressed along with
others in an update.
