Black Bars at Render; Output Dimensions & PAS seem fine
COW Forums : VEGAS Pro
John Papas
on Oct 10, 2014 at 5:57:38 am
Hello.
Here's the issue, this picture's dimensions are 1920x1080, it looks fine on my preview, but black bars appear at render.
Snapshots showing some render settings. Project and preview dimensions are also visible:
Output dimensions and PAS seem fine.
On the media's properties, I have checked "Maintain aspect ratio" and "Disable resample".
I tried changing those, did not help at all.
I must be missing something. Any ideas would be greatly appreciated! :)
Solved: It only appears wrong while it renders. When the final product is ready, there are no black lines.
Timur Zavid
Re: Black Bars at Render; Output Dimensions & PAS seem fine
on Oct 11, 2014 at 9:22:39 am
Having same exact issue, top and bottom black bars, even after unselecting maintain aspect ratio option, and setting everything to 1920 x 1080 and disabling resample. :-/
John Rofrano
on Oct 11, 2014 at 2:59:16 pm
Glad you figured it out. I couldn't help but notice from your screen shots that your project properties are set to 29.97 fps but you are rendering 50 fps. You might want to change your project to 50 fps (or at least 25 fps) because 29.97 fps is can negatively impact playback and it will change all of your timing decisions while editing.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Timur Zavid
on Oct 11, 2014 at 7:12:52 pm
I still have the same issue, any ideas how to fix it.
It's the render that has the black lines for me, preview window looks just fine.
