Convert 5d mark iii footage to Edit with Vegas Pro 12
COW Forums : VEGAS Pro
Joao Carlos Schwalbach
on Oct 7, 2014 at 7:42:05 am
Hello,
I have to edit a concert shot with 3 5D's make iii's.
It's better to convert them into a more friendly format right?
Which convertors do you recommend? Free would be nice, but I am willing to pay if that makes makes a big difference.
It's a lot of files so Batch Option would be a priority.
Thanks in advance
j
Dave Osbun
Re: Convert 5d mark iii footage to Edit with Vegas Pro 12
on Oct 7, 2014 at 8:07:20 am
Why can't you just edit them in their native format? Aren't the files it spits out .mov files? I edit MOV files regularly with no issues.
Dave
Mike Kujbida
on Oct 7, 2014 at 10:35:01 am
It's been reported here and elsewhere that Vegas does not handle large numbers (50 or more as I recall) of MOV files very well.
If that's the case, my suggestion is to convert them to MXF which Vegas handles easily.
Use the Batch Render script built into Vegas to transcode multiple numbers of files.
on Oct 8, 2014 at 8:22:45 pm
Well, I have started to edit with the native format. So far so good.
Thomas Roberts
on Oct 19, 2014 at 7:31:53 pm
Hi Mike,
What MXF settings do you recommend for Canon DSLR footage?
Mike Kujbida
on Oct 19, 2014 at 10:41:03 pm
Thomas, I'm not at my computer right now so my apologies if I mess this up. I would use the MXF EX HD 1920 X 1080 setting.
Thomas Roberts
on Oct 19, 2014 at 11:01:11 pm
Mike,
Thanks, I'll mess with this and get back to you guys :)
Thomas
Mike Kujbida
on Oct 20, 2014 at 2:22:33 pm
Thomas, I was close on my name guessing :)
Bob Peterson
on Oct 7, 2014 at 3:31:14 pm
Vegas handles video files from my 5D II without a problem, but I have not used large numbers of clips. The comments about a 50 file ceiling, and the workaround using Vegas are well taken.
Steve Rhoden
on Oct 7, 2014 at 3:57:19 pm
Why not just edit them as they are. There is a talked about issue
with having more than 50 on the timeline, But i've never had that
issue.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Norman Black
on Oct 8, 2014 at 4:26:35 am
You can edit the MOV files directly. Vegas bypasses Quicktime for typical DSLR MOV files, Canon included, and decodes these directly with its own internal decoders. The 50 file Quicktime issue does not apply.
on Oct 8, 2014 at 7:14:44 am
Thank you.
I am editing as they they are. Sometimes vegas gets slow but I can work with that.
Let's see what happens when I start throwing plugins around.
cheers
